Yup, all good! All modern nimh chargers charge at constant current and look for a change in either temperature or more commonly a negative gradient on the voltage required to maintain that current, then switch over to a trickle. All nimh cells will give that "step" down in charging voltage as they approach fully charged, so all nimh chargers will charge the cell fully regardless of capacity). There's a couple of minor exceptions (if you charge rediculously slowly the step can become indistinguishable as it happens really slowly (the charger looks for a drop of so many millivolts per second), or if you charge really really quickly you can way overshoot before spotting the drop. But most chargers and most cells fall within a compatible range.
