Viewing 7 posts - 1 through 7 (of 7 total)
  • Reba 29er – anyone fluttering?
  • Kryton57
    I’ve got a vibaration from upfront which if I “bounce” the front wheel appears to be the wheel end of my fork – Reba 29 120mm.
    I’ve checked the headset etc but can locate another source and it makes the front feel “loose” when riding.
    Is this common/happening to others?
    STATO
    How old are they, what you describe is worn bushings.
    cjr61
    I had something on mine and I was being a muppet and my QR wasn’t quite tight enough…. 😳
    Assume you’ve checked rotor, brake calliper and the other obvious tighten-able bits?
    Kryton57
    They are 2016’s 4 rides old. They are 15mm bolt through done up tight with a screw in Mt Zoom bolt. Same effect with a RS Maxle.
    faustus
    Wheel bearings shot?
    Kryton57
    Nope, fine on the other bike, 100mm Reba on that one.
    STATO
    Fork Bushing have play, otherwise they wouldnt slide. You need to take it to a shop to get someone who knows whats right to tell you if its acceptable or faulty.
The topic ‘Reba 29er – anyone fluttering?’ is closed to new replies.
