No – easier to buy a 120mm if you want 120mm. Are you looking new or second hand?
New solo air needs a spring change. From what I know most dual air’s will but some of the 80/100’s will be OEM and can be different – anything second hand could be different as you don’t know the history. Only way to tell 100% is open them up and see what’s on the air spring.
If you can find new old stock retail version dual airs that should be a pretty safe bet. There was also another thread on here about the same thing a while ago, can’t find it though.
