And i was proved correct with instant good responses so thank you 🙂
I have a Pitch Pro, my RP2 has recently just given up and with it costing £90 to have it fixed i am in the dilemma of whether or not it's worth it?
A brand new one on sale is only 150, which may be double, but obviously is brand new. My second option is to swap out for a coil shock which for some reason have always majorly appealed to me.
So in theory, if i was to measure the eye 2 eye of my current RP2, on my Pitch right now, this would be the desired length i require?
In regards to the 'compression of say 23mm', does this change depending on the eye 2 eye mm, or is it possible to have the following from my previous example:
140mm – 28mm Stroke
140mm – 56mm Stroke (Made up for the sake of the question)
If the answer is yes it can be different, what issues arise?
Thanks again everyone this is much appreciated.
TomO
