I noticed some play in the rear shock on my Capra. I have traced it to the shaft end. I noticed that before I took it off one of the spacers was loose and I could rotate it. The top end is solid as, so no problems there. It seems like the axle/pin is slightly longer, by about a mm when the spacers are on the axle/pin. When I took out the top end to check the play on the bottom end there was a lot of movement, however it is not coming from the bushing, it is coming from the loose fitting bolt. It is pretty loose inside the axle.
Questions – should the spacers not be slightly longer than the axle so they press on frame, not the axle it self? These then press everything together to firm things up. It seems like there is a spacer/washer missing somewhere.
Is it normal for the axle to wear out internally? Seems odd to me. My stump jumper was fine after 9 years and this is only 2 years old.
Is the entire mounting/bushing just shagged and would it be better to get a new set up, ie TF tuned one. My worry is that the bolt will still be loose inside that axle as well.
Opinions on what is wrong here or what needs to be done?
