Got a 2012 Five with the original RP23 shock, which went back to mojo once for being wallowy and blowing through the travel, a volume reducer was inserted and a some valves replaced under warrenty, but it has start e d doing it again, i know you bottom out from time to time, but what happened then and is happpenng now is not just ejection of the o ring, but also the tyre contacts the seat tube making an unpleasant sound/feeling. There are black scorch marks on the frame from when it happened originally, its almost like the shock is beyond fully compressed.
Any thoughts recommendations, is it worth getting the shock serviced again? Or it is time for something more tolerant, also is there a problem with the frame or does it acome back to the shock, as for the 3 years in between, i’ve bottomed out but not had the tyre contact. I ended up leavig propedal on for the rest of the ride yesterday and it didnt do it again.
26″ stans flows with old 2.2 rubber queen ust, so not the fattest rubber in the world.
