Just bought a 2nd hand Kona Entourage,needs little bit of TLC,just done BB and headset,the rear shock has play when you lift the bike,I had my mate check and measure the bushings and ordered a set from Offsetbushings,just the standard but i typed the wrong number so instead of 22mm i put in 20mm,
Will this cause any problems or should they be ok??Had hoped they would replace them for the right size,but due to them being machined to the size i asked for the declined,Do i just keep them in,buy the right size or is there another solution
cheers
