It’s the internal damper shaft. Which from the sound of things they went from 9.5mm down to 9mm so to get the replacement I need a dead shock of the same size to rejuvenate mine.
Had a look on pink bike but by the time you’ve purchased serviced it and tuned it it works out about the same as the newer float 2014’s on CRC.
Thanks for the offer garage dweller because of the active nature of the rear of my bike I do tend to use the propedal a lot.
Thanks for the advise mikey I’ve got one last hope with rsf finding a part if they can’t I’ll give them a shout.
Are monarch’s worth looking at? Always thought they we not as good as the fox but would be interested in hearing views as even if I go down the refurb route I’d prefer to have a decent shock rather than one that is hampered due to poor design.
