Good evening,
The top of the little clutch switch lever on my rear mech (XT mech on my Whyte T-129) touches the frame when I move to the smallest sprocket on my cassette. This effectively stops the mech moving all the way in and from selecting this gear (the chain remains, stubbornly, on the second sprocket).
Oddly, if I move the mech’s clutch switch lever to ‘off’ the mech can move past the frame and select the smallest sprocket (because the offending clutch switch lever has been moved off to the side). I should also mention that this happens whichever front ring I’m on. Other than this, the bike switches fine.
I’ve a dark suspicion that the solution might involve something called a ‘b-screw’, but I’m really not sure. Can someone advise?
appreciated
sc
