Hi all, I've always built rear disk wheels asymmetrically, that is the trailing spokes on the drive side (those pointing towards the back of the bike) heads-in/elbows out and the leading spokes on the disk side (those pointing towards the front of the bike) heads-in/elbows out.
However in the CK manual it states, The front ISO should be laced 3-or-more-cross with the rotor (left) side pulling spokes (relative to braking direction) heads out/elbows in (when laced 3-cross). The final cross of the pulling spoke must be on the outside so that, as braking force is applied, increased pulling spoke tension will pull the crossed spokes towards the center of the hub and away from the caliper. Lace the wheel symmetrically.
But it doesn't mention the pattern for the rear.
What's the opinion of the wealth of knowledge on here?
