Right – I’ve set them up before, but I can’t get this one right, can anyone help?
It’s a Sram Rival 1×11 and the symptoms are:
• If indexing is set to go up the block (towards low gears) correctly, it is slow to respond coming down the block again.
• This gets worse as you go up the block – tapping to go to a smaller cog from one of the 3 biggest ones often results in nothing happening at all. Towards the smaller cogged end of the block, it’s not as bad. It will move, but in its own time. Occasionally it will ghost-shift into a smaller cog.
• With the bike upside down and me spinning the pedals, same thing happens. If I pull the derailleur myself, it will shift.
• High- and low-limit set correctly (to my eye at least); B-tensioner adjusted per instructions.
Any ideas? It’s as if there’s friction in the system – but could this also be a bent mech/hanger symptom? (Bike fell over and hit the patio hard a few weeks ago, and that’s in the back of my mind. It *looks* straight to me, but sometimes not…)
Thanks : \
