Hi,
I have a hope 2 evo rear hub and sram 10 speed cassette setup. I have noticed after my latest ride that the nearly all of the rings have about 3/4mm play both ways. The last 2 (largest) rings don’t move and the first ring doesn’t more, but the rest can be moved independently of each other by quite a bit.
Is this simply and tightening issue (away, don’t have correct tool with me to test), or is the cassette done? I’ve had the set up for less than a year so reasonably new. Not cheap kit so expected a little more.
Bought the cassette from chain reaction so wondering if I can send it back if it is the problem?
Any advise would be appreciated 🙂
Thanks
Rob
