It’s not clear if Fabsil is a coating or just some sort of Scotchguard type PTFE. Hence the thread, if anyone has any experiences
I have no used it BUT if you want to get an idea of what is in it you can take a look at the coshh data sheet.
Edit: After having a look at the data sheet its not that useful!
http://www.farnell.com/datasheets/1536436.pdf
2-HYDROXY-4-(OCTYLOXY)PHENYL_PHENYL 217-421-2 METHANONE1843-05-6 < 1%
BUTANOL-norm 200-751-6 71-36-3 < 1%
NAPHTHA (PETROLEUM) HYDROTREATED 265-150-3 HEAVY 64742-48-9 60-100% Xn;
ZIRCONIUM BUTANOLATE 213-995-3 1071-76-7 < 1%
So apparently up to 100% Naphtha!
Naphtha is obviously the solvent. I don’t know if PTFE is soluble in naphtha.?
Google say no but..
https://www.researchgate.net/post/What_are_suitable_solvents_to_dissolve_Teflon_Estane_and_Viton
“Dissolving fluoropolymers is hardly an option, they are stable in most solvents. If the pores are large enough, you could also consider buying PTFE fine powder and dispersing it in some hydrocarbons”
So it may be PTFE powder.
Overall I feel this post has been of no use but I have learnt that PTFE being a high molecular weight polymer (hence why it is so slippery) will not dissolve in a solvent, but maybe disperse with a hydrocarbon.
You are welcome!
