Thing they’ve missed is that a gauge doesn’t have to be read. You can glance at a gauge and see that I am going at X speed, or have Y amount of fuel left….
You have to read a number.
Which is why digital speedo readouts always seem like a stupid idea to me.
In competition vehicles it’s always been the practice to set gauges/dials with the optimum position of the needle verticle, that way any deviation immediately attracts attention.
I’m used to the needle being almost vertical at 60, and horizontal at 30, so I can judge my speed fairly accurately, just needing a tiny glance to double check.
I guess that having a digital display, properly designed and laid out, would work ok, as someone said, you get used to things fairly quickly; I got used to judging my speed in my Puma with the tacho, I discovered that 3000rpm in top equalled 60mph, and I worked out other speeds as well, using the digital speedo that was available, and soon generally ignored the speedo.
Can’t judge it the same in the Octy, though.
Of course, the best set-up is a true HUD system, including satnav, then you don’t need to look down; Jaguar have a proposed system where the satnav shows a ‘ghost’ car superimposed on the screen, which you follow, instead of using an arrow, which sounds like a good idea in principle, as people are quite used to following other vehicles.
