kenkujo: Any users of the RCT3’s care to comment.
I’ve just got a set of RCT3’s and the rebound adjustment appears to have no effect between max (hare) and min (tortoise) settings in either the ‘open’ or ‘threshold’ settings, i.e. the rebound is very quick and no damping is present.
It’s a dual air and running both chambers at approx the same pressure, filling +ve first then -ve.
Also the low speed compression setting appears to have little effect.
I’ve tried purging all the air out to test the compression and damping circuits, but it behaves the same way.
Is the fork goosed? Is it a known problem or have I set the fork incorrectly somehow?
Not sure if it’s a problem, but playing with my new Dual Air RCT3 Revs (29er) yesterday I did think that the effect of the damper and LSC was subtle. Not exactly non-existent. If I turn the rebound damper fully on it does seem to return a bit slower and I can hear a sort of whooshing noise, suggesting oil being forced through a small hole. Turning the rebound damping down makes the noise decrease then disappear and I guess I can feel a difference in the rebound speed. But it’s not huge.
Of course, if the difference were huge it would probably mean that the options at either end were basically unusable. With it being more subtle it could just mean that I have 13 clicks of useable options. Or they could be broken 🙂 I’m going to reserve judgement until I’ve had them out on the trails for a few rides.
