Had a productive couple of hours today, with the help of my Dad (got to give him a project whenever they come up to visit), turning this:
Into this:
Just got to trim a few of the coach-bolts and add the shelf at the bottom. Total material cost = just over £61 and I’ve got half of the bag of 50 coach-bolts left over!
Apologies to the STW Vice-istas but it’s a “no name Chinese vice” that only cost me £31 on E-Bay, have to admit it’s slightly larger than I expected but it all works smoothly and will do the job.
Now to start on the wiring for the lights and sockets…..
Is the bench secured to the wall in some way? It’s quite tall compared to depth. Mine is like that but designed it that way (max floor space) and have fastened it to the wall.
Good idea about fixing to the wall, was going to fix to the floor only but will now fix to the wall as well.
There will be external hinges (fixed through with coach bolts) fitted too before anything valuable gets in there. That’s in addition to the full, wired, alarm….
You got Halfords tool boxes that weren’t crushed on the pallet before delivery? Even their display ones were damaged. what were you saying? Something about a bench..
I wouldn’t worry too much about strength, if it is like any other workbench it will be covered in crap for 99% of its life so wont be used as a workbench much 😉
If it’s not flush against the wall (hard to tell from pic) consider an upstand or baton or something across the back. So when it’s got a shelf full of boxes of crap and you drop a small bolt it doesn’t roll off the back and down behind it never to be seen again.
“Trying to make one myself but cannot seem to find decent timber online from somewhere close by.”
stop trying to buy wood online then
wood is one of those old fashioned things taht you really want to get on the phone and speak to someone about – you also want to be collecting your self or as a ordinary punter you have a high risk of getting the warped pish that no tradesman would accept on their job.
my first home brew bench …..which morphed into below with some scraps a damaged pack of laminate flooring and some old decking i rescued from a friends.
and before we knew it – a twin was born…. as once the pillar drill and bench grinder were mounted on the first one there wasnt much room.
dont you fancy a mid shelf under there ? i think youll find you waste alot of space or end up moving stuff loads when you drop a small bit…..
Great advice, and something that’s been on my to-do list for the past couple of years 😳
Finally took a picture of mine – all stuff scrounged where possible (friends and Freecycle). I did buy the magnet strips and workbench itself (a cheap offer from Lidl at £60 for all of it, supplemented with bracing made from chipboard flooring panels (also used to create the backboard).
Feel free to critique my benches, mostly made from what was to hand or freely/cheaply available.
Recent addition is the extention to the main bench with some 2×4 and an Ikea Pax wardrobe side panel (from the scrap pile) for the top. Nice wipe clean and easily replaced. Main section where the vice is bolted has some serious timber underneath (section of base from a shipping crate for machinery). Rear upstands are the bases from an old set of drawers.
Frame is 2x4s with 4×4 fence posts for legs, top is inch thick CLS
I still need to fit a vice (i’ll re-enforce the area underneath the vice with the offcut CLS I have left over) and make a shelf across the leg braces but I’m pretty happy with it for a days work
