Nowhere near enough gears.
Gears for queers fam.
Silver headset spacers Fail
Eyesight fail, those are some OG FSA crabon fibré spacers right there.
It loses points as the rear valve/logo alignment is about 7° out
This is a valid point and will be rectified when I can be bothered.
Oh and fit some real pedals on too
This is not a valid point.
Forks too short, brake cables too long, chain too slack, very poor valve alignment, forks don’t match the bike.
You’re just pointing out the obvious, try a little harder.
I think the front disc is a bit small at 200mm,
I’m a little worried that the QR will get pulled out with anything bigger
Rotors *look* like they’re on back to front too
Yeah, as you say, arms are correct, it’s just the design of the rotor.
AYHSMB
