Ah is ‘sucked’ by the device on charge, so as long as the Ah exceeds what the Pi needs you will be fine.
Voltage is ‘pushed’ and this is the one to be careful with. I can’t see that + 0.1v will be an issue…but I’m no expert 🙂
The important thing to check is the polarity…some devices have the centre tip positive, others will have the sleeve as positive. Be careful 🙂
Edit: But then we are talking USB here I presume, so the polarity is not an issue, also I would have thought 5.1v is within the standard as I’m sure most people (like me) mix and match all their 240v – USB plugs and leads, and I’ve never had an issue.
P.S 1Ah = 1000mA. A quick Google says the Pi needs 500mA or 700mA depending on the model you have.
