What are the advantages to using ROS over just doing robot stuff in Raspbian (where there is plenty of guidance from other people doing stuff)?
ROS would run on top of Raspbian (or whatever OS). It’s just a framework for robotics stuff, which has support for various sensors and algorithms.
So e.g. you could just take a pathplanning component off the shelf, or a sensor driver etc. Depends how complex a robot you want to make I guess! I immediately think some sort of autonomy, sensing & acting. But if you want something that just drives about the place you can do something a lot simpler!
Has anyone stuck a pi to a quadrocopter yet? I really, really want to make one that can chase my cat around the house.
I suspect you couldn’t do the vision processing fast enough on a rPi, unless it’s simple like a black cat on white carpets.
Or actually, attach IR leds to the cat’s collar, IR pass filter on a camera then it’d be dead easy…
