Viewing 22 posts - 41 through 62 (of 62 total)
  • ran over a toddler this morning
  • spacemonkey
    Thinking about it, I’d +1 to reporting to the plod.
    Who knows if the papa is capable of guessing your commute/timing and turning up announced one morning …
    pdw
    The hoods are an obviously compromised position for braking. If someone gave you a brake lever and said “pull that really hard” would you really put your hand on the far side of the pivot and try to press it from there? Or would you wrap your fingers around the tip of the lever and the handlebar and squeeze directly perpendicular to the lever?
    With a decent set up braking from the hoods is fine most of the time, but it certainly wouldn’t be my first choice for an emergency stop.
    HoratioHufnagel
    I’ve started using a hybrid now i’m commuting in the city too.
    I’ve fitted new cables, new pads and cleaned the brakes/rims, but my road brakes (Shimano r650) are terrible compared to even cheap pair of V-brakes.
    I find braking from the hoods gets a bit painful when doing it repetitively too (I’ve about 50 sets of traffic lights on my commute!).
    coolhandluke
    I left a tyre mark across the back of a small child once.
    Is it wrong that that ^ made me laugh?
    whatnobeer
    This is also why Campag brakes are far superior to SRAM and Shimano ones. They actually work from the hoods and mean you don’t run over small children.
    davetrave
    coolhandluke – Member
    Would’ve been better if it’d been a skid mark…
    brakes
    I would recommend upgrading to man-hands.
    IanW
    /\ what he said.
    I have mans hands and can easily lock the wheels from the hoods, mind you I always slow down around kids and similar hazards so wouldnt need them.
    fasthaggis
    El Vino Try fitting V brakes with travel agents if you want more braking on your CX
    devash
    I had problems with the canti brakes on my Specialized Tricross for a while. Nearly sailed into the back of a van doing an emergency stop, and took out a Labrador which ran into the road during the commute one morning (fortunately I stayed up, dog was fine, owner very apologetic).
    Replaced the brake pads with some Kool Stop dual compound and learned how to properly set up and maintain cantis and now the braking power is much better.
    Still intending on upgrading to a disc road frame in the future though.
    peabrain
    I’ve been on the other side of this, but luckily my son wasn’t hit.
    We were at one of those bikefest things, and there was an airbag set up. Riders were cycling very fast down a path towards the airbag, and we were walking up beside the path.
    Quick as a flash my 2 year old ran out in front of a bike. The (lovely lovely) young man stopped his bike just in time. I said something along the lines of “Thank goodness for brakes!” All the BMXers looked at me and said “He doesn’t have brakes…”
    irc
    So hit and run when her husband finds out and gets angry. It takes 10 minutes and covers your arse.
    It isn’t a hit and run. Cyclists are under no legal duty to report any accidents. That only applies to drivers of motor vehicles.
    MrNice
    have we really not yet asked “what tyres for running over a toddler?”
    brakes
    Maxxis Minion?
    MrNice
    or high (chair) roller?
    allthepies
    Furious Fred (the father)
    Northwind
    Maxxis Childrollers.
    aracer
    Maxxis Shorty?
    IA
    Kenda Kiddies?
    Northwind
    Kinder Excavator
    cfinnimore
    Edit: This one time a child scootered into my wheel.
    Mum went MAD. I just went home. Child’s fault.
    molgrips
    I can brake almost as well from the hoods. However in very wet conditions nothing works, hoods or drops, with my 105 brakes. Apparently upgrading to Ultegra helps.
The topic ‘ran over a toddler this morning’ is closed to new replies.
