If you start getting chain drop, check the chain. Mine was dropping, checked chain and it was fairly worn, replace (cassette had to be done also given the amount of wear), no more chain drop.
I’ve got Works Components rings on both my HT and full sus. Both have lost their black coating on the teeth, but otherwise are fine. Yes they’re worn a little but still work fine, but it is more sensitive to a worn chain. I go by running chains into the ground and don’t do the replace chains to save a cassette, as I found it I wasn’t getting any more life from a cassette anyway, only spending more on chains (though okay if the chain snapped and was bad enough to need a new chain then new cassette was guaranteed, but a) I buy kmc chains, no snaps, and b) if they snap, use a link, chain still good). All that said, if a narrow/wide means more frequent chain replace then may have to go for the early change to avoid the cassette change after all.
