Got a black set of Deus XC cranks. 175mm long. Fits and external bottom bracket. Got a set of 22T & 32T chainrings and a 34T bashring to go with. No chainring bolts though. Happy to spilt.
Needs a bottom bracket and the preload washers. CRC have the washers - http://www.chainreactioncycles.com/Models.aspx?ModelID=29489
Fair condition with heal rub marks but nothing that effects the performance.
£75 posted.
Also got a set of 635mm wide, silver Deus XC Low Riser (about an inch) bars. Oversive. A few cosmetic scratches where the components were fitted but nothing that effects performance.
£17 posted.
Also got two sets of Wellgo V12 copy flat pedals. These are the cartridge bearing version.
One is black. Been used loads and the black is pretty much scuffed off the pedal surface. Slight play in one set of bearings but it's been like that since their first outing. £8 posted
The other is White. Been used only a few times. A couple of scratches but nothing major. Bearings still tight. £10 posted
I'll do both pairs for £16 posted.
E-mail for pics.
Happy trails,
mk1fan
