Have had these brakes for a while and with the back brake it had always seemed to be the case that when you pull the lever the first pull is almost to the bar and very weak but the second pull is perfect and sharp, meaning I have to keep dabbing it all the way down so.that it is primed in case I need to break hard.
I tried for the first time ever to bleed them the other day to see if that helped (plus I had lost a load of fluid out of the front one), the front one was a ‘ great success!’ however the rear has stayed the same, this could be due to my novice brake bleeding skills.
any suggestions?
