I received a set of used brakes from STW some time ago, and it appears that the pistons are jammed so might as well do a full rebuild.
Could anyone suggests the parts I will need?
I already have a bleed kit and 5.1 oil.
So far I have added:
4x Pistons http://www.chainreactioncycles.com/Models.aspx?ModelID=9218
2x Seal Kits http://www.chainreactioncycles.com/Models.aspx?ModelID=5086
1x Bore Cap Tool http://www.chainreactioncycles.com/Models.aspx?ModelID=5244
Do I need anything else? There are also Master Piston Seals (which I am unsure whether I need them or not, and how many) http://www.chainreactioncycles.com/Models.aspx?ModelID=20281
Much appreciated.
