So the axle is slightly to small?
Yep – although it’s the same axle I took out when I dismantled the bike to get it powdercoated. It’s a GT BMX
is it only one side thats no turning the bearings, or both?
It’s ‘loose’ both sides, although I can easily turn the bearings with my finger on both sides.
Van Halen up there said When you bolt the crank arms on it will clamp the inner bearing race between the crank and centre spacer. The bearings should then be turned. which kind of makes sense – the washer/spacer thing protudes on the inside edge which looks like it should engage the bearings with enough pressure. Trouble is – when I apply the pressure – it all siezes up!
It looks like one of those cheap setups, does the axle have a “flange” on one side that prevents you from moving it through any further?
No – it will drop through if I let it
Thanks so far!
