- This topic has 64 replies, 20 voices, and was last updated 13 years ago by molgrips.
Question about excercise and fat loss
thisisnotaspoonFree Member
OK so the theory goes that a long slow ride is best for burning off fat so a ride in zones 1-2 will burn off arround 60% of the calories as fat.
Presuming I don't have time for lots of long slow rides what burns off more fat;
a) 2 hours at a fast pace, burning off more calories, but a smaller proportion of it fat.
b) 2 hours of bimbling allong in the 'fat loss zone' according to my HRM.
geoffjFull MemberDoing more work is going to use more energy.
2 hours ard is more work than 2 hours slow and so result in more fat being used.BUT 3 hours bimbling along in the fat loss zone, may result in greater fat loss than a 2 hour full on blast.
TandemJeremyFree Membera)
its all about calories in and calories out. a) will burn more calories
Fresh Goods Friday 696: The Middling Edition
Latest Singletrack VideosFresh Goods Friday 696: The Middlin...BigDummyFree MemberYou are a deluded and credulous fool. I have watched "Alien Autopsy" to a very high level in my impassioned search for enlightenment and I can't be bothered arguing with you.
LHSFree MemberFirst, it does not matter where the fuel comes from while you are exercising; in the end (ie later in the day) your body will replenish and rebalance your energy stores. So a calorie surplus will always end up increasing your body fat; and a calorie deficit will always end up reducing your body fat. The source of fuel while you are exercising is irrelevant.
Second, what matters is the total amount of calories you burn; not the proportion that come fat. If you exercise at lower intensity, a higher proportion may come from body fat, but this may be a smaller absolute number of calories.
molgripsFree MemberRight, well assuming this is not a troll, and according to what I understand is generally accepted:
They will both burn off a similar amount of ACTUAL fat, although a) will result in more calories being burned. a) will take more out of you so you won't be able to do it as often. a) may also make you insanely hungry so you might not be able to resist filling your face when you get home which may result in the ingestion of more fat.
You can burn fat up to a certain level of intensity, and then above that you start to burn carbs in addition.
b) is better in theory for burning up fat, but you have to go for much longer than you would a), but it's also easier on your body which enables you to do it for longer (assuming you have time). I can ride b) for 15 hours a week, but couldn't hammer for 15 hours a week.
It's also worth noting that b) actually trains your fat burning metabolic pathways which allows you to burn more fat – which is why cyclists do it in the winter time.
But if you only have 2 hours a week then definitely a).
LHS – it's more complex than you say.
TandemJeremyFree MemberFirst, it does not matter where the fuel comes from while you are exercising; in the end (ie later in the day) your body will replenish and rebalance your energy stores. So a calorie surplus will always end up increasing your body fat; and a calorie deficit will always end up reducing your body fat. The source of fuel while you are exercising is irrelevant.
Is correct.
crikeyFree MemberPresuming I don't have time for lots of long slow rides what
burns offgets rid of more fat;Just stop eating as much, then instead of having to actively do something to get rid of something, you just do less of something to get rid of something.
Put the cake down, step away from the chocolates…
TandemJeremyFree MemberTINAS – you just wanted to start this argument again didn't you? Eh? admit it!
LHSFree MemberLHS – it's more complex than you say.
In relation to the other thread about forum aggressiveness, I accept your point of view from being different from mine and shall leave it there. 😉
molgripsFree MemberI can't believe I am wading into this, but…
If you use up your carb stores, you'll feel really hungry, prompting you to eat more. If you don't, you'll feel crap.
If you use your fat stores, it has no effect (mostly) and you'll eat normally.
The above is not derived from reading marketing guff!
LHSFree Membergoing soft LHS?
Hang on a minute TJ, you agree with me so can't pick a fight!! Or can you? 😉
crikeyFree MemberI must admit in the new forum style of constructive disagreement, that I am somewhat at odds with the idea of a preferential fat burning style of exercise….
Professional athletes who have very low body fat percentages would presumably be unable to exercise at low intensity if what you fat burning fellas say is true….
However, I respect your position, and I fully appreciate your right to be wrong.
cynic-alFree MemberI'd go a). It's less boring too…I'd focus on fun as that's as good a motivator Shirley?
thisisnotaspoonFree MemberTINAS – you just wanted to start this argument again didn't you? Eh? admit it!
Nope genuine question, was on the cross trainer at the gym (I can't run on a treadmill so its as good alternative for warming up on, that and the rowers, but they dont have programs) and was wondering what the point of the fat burning progam was when there was also a calorie burning program. Preumably its for proper fatties who's heart can't cope with the next step up because most people would die of bpredom well before coronary heart disease on those things.
The answer is about what I expected, you burn off the same rate of fat/hour once you get going and thats supplemented by jelly babies.
jonny-mFree Memberthere is no such thing as "fat burning" its all about the intensity or effort you put into exercise. the harder you work the more you benefit you get. its as simple as that. A 30 minute steady ride will use less calories than a 30 min hard ride. therefore the harder the exercise is the more calories you will use up.if you put less calories in your body and you expend more than you put in you will lose "weight" your basal metabolic rate also comes into the equasion aswell which is how many calories you need to just "get through the day"but i wont go too much into that just yet….
trickydiscoFree Memberthere is no such thing as "fat burning"
Isn't there? So we don't use fat as source of fuel when exercising… in any circumstance?
So how do these athletes drop to below 10 or 8% body fat composition?
If you want a great book on the subject of physical performance and how we fuel the body then read mike stroud's book :
[He trekked across antartic with ranlph fiennes
nickcFull Memberif you don't, you'll feel crap.
depends on the individual surely? I can do quite long miles / hours on the bike come home and not stuff my face. In fact on Sunday after 4 hrs in thx heat in the chilterns the missus had to remind me to eat.
TandemJeremyFree Memberindeed nickc. Well fuelled with long acting carbs before and during I often don't need to eat much after a ride – even after a long high intensity ride.
dangerousbeansFree MemberSo why do sprinter have lower body fat than marathon runners? At Olympic level it's about 6-10% for the former and 8-12% for the latter.
Sprinters never train in the fat burning zone.
KevaFree MemberAgreed also. I rode round Whites and Wall in 3h 45mins on Saturday, didn't eat for two hours after getting back. Was too busy lying in the sun.
Kev
KevaFree Membermines 14%… I'm neither a sprinter or a marathon runner, and at 41yrs old I'm miles away from Olympic level.
Kev
trickydiscoFree MemberSo why do sprinter have lower body fat than marathon runners?
Probably because marathon runners don't do lots of weight training like sprinters do. Sprinters train for strength and power
molgripsFree Memberthe harder you work the more you benefit you get. its as simple as that.
Not really. If you work hard you're training different metabolic pathways than if you go easy. That's why cyclists do base training (long slow) in the winter and speed training (short fast) in the summer.
Maybe for you, with your idea of 'high intensity'. But we're all physiologically different. I should've said 'you may feel like crap' etc etc. I know I do, but I have a sprinter's physiology.
My theory is that the people who are carrying a few extra lbs are the ones who tend towards sprinting, power efforts, fast twitch muscle, and muscle gaining and so on.
I think that they have to eat a lot of fat in their diets to ensure they don't go below dangerous fat %ages.
toys19Free MemberThe whole fat burning zone thing has been slightly misapplied. TJ and others have got it right.
If you take it relatively easy when exercising then your body uses mostly fat to provide its fuel, when you need to go hard it asks for more fat AND adds in the instant power of locally stored carb fuels (glycogen) to up the power. So a) is better for weight loss because it will use more fat (as well as your glycogen stores). Your body does not ever use fat only or glycogen only, unless you have run out of one of them..
molgripsFree MemberHow much fat you can burn though is limited by how much oxygen you can supply. So over a certain point you can't burn any more fat and rely on carbs. This is your lactate threshold and is currently about 200W for me 🙂
toys19Free Membermolgrips – Member
You cannot burn any more than you are currently burning, the mistake is thinking that high intensity exercise does not burn fat, or burns less fat, this is just not true.
crikeyFree MemberHow much fat you can burn though is limited by how much oxygen you can supply. So over a certain point you can't burn any more fat and rely on carbs. This is your lactate threshold and is currently about 200W for me
Molgrips, you're not quite getting this…
You don't 'burn' fat.
Fat is one way that an energy substrate is stored in your body.
In order to use up that particular energy substrate, it gets converted into glucose then used up.
In order to use up that energy you need to use oxygen.
Your 'lactate threshold' is nothing to do with fat metabolism; it represents the point at which aerobic exercise becomes anaerobic.
Go and have a read about basic human physiology/metabolism…
molgripsFree MemberIn order to use up that particular energy substrate, it gets converted into glucose then used up.
Yes, I used the word 'burn' as shorthand.
No, that's the anaerobic threshold. People use these terms differently, but I am using the term lactate threshold for the onset of lacate production, not the point where accumulation outstrips removal.
I have been.
iDaveFree Memberlactate threshold is bullshit
crikey, do you think at the threshold you could exercise without oxygen then? think about what you claimed….
given that a threshold in performance capacity, which some people erroneously think is a lactate threshold, occurs at 60-90% approx of max oxygen capacity, that would suggest that you don't become anaerobic at the threshold.
TandemJeremyFree Membercrikey. I had to give up. Please try to put him right tho. Should we club together and buy him a textbook?
molgripsFree Membercrikey, do you think at the threshold you could exercise without oxygen then? think about what you claimed….
No. Wtf?
So set me straight then. When I did a blood lactate test, lactate levels stayed constant to 225W and then started to rise. Is this not lactate threshold?
iDaveFree Membermolgrips, lactate is produced at rest
maybe you mean lactate accumulation?
maybe you don't know what you mean?
iDaveFree Memberthe crikey was at member crikey, not aimed at you molgrips, though maybe….
iDaveFree Memberwhat do you think the rise in lactate levels mean?
what relevance do they have?
lactate is a pretty important fuel in endurance exercise…
makes you wonder?
TandemJeremyFree MemberLactate as a fuel? I was taught it is a byproduct of anerobic metabolism.
this is my understanding
This is more about metabolic disorders than exercise but the basic pathways are the same.
Most cells in the body normally burn glucose to form water and carbon dioxide. This is a two-step process. First, glucose is broken down to pyruvate through glycolysis. Then, mitochondria oxidize the pyruvate into water and carbon dioxide by means of the Krebs cycle and Oxidative phosphorylation. This second step requires oxygen. The net result is ATP, the energy carrier used by the cell to drive useful work such as muscle contraction. When the energy in ATP is utilized during cell work (ATP hydrolysis), protons are produced. The mitochondria normally incorporate these protons back into ATP, thus preventing buildup of protons and maintaining neutral pH.
If oxygen supply is inadequate (hypoxia), the mitochondria are unable to continue ATP synthesis at a rate sufficient to supply the cell with the required ATP. In this situation, glycolysis is increased to provide additional ATP, and the excess pyruvate produced is converted into lactate and released from the cell into the bloodstream, where it accumulates over time. While increased glycolysis helps compensate for less ATP from oxidative phosphorylation, it cannot bind the protons resulting from ATP hydrolysis. Therefore, proton concentration rises and causes acidosis.[3]
The topic ‘Question about excercise and fat loss’ is closed to new replies.
