Viewing 14 posts - 1 through 14 (of 14 total)
  • Quantum computers
  • flip
    Effectively, it can try all possible solutions at the same time and then select the best.
    Please someone explain how they work before my head explodes..
    http://www.bbc.co.uk/news/science-environment-22554494
    Liftman
    Lets start at the beginning, do you understand quantum physics
    piemonster
    Yes, carry on
    piemonster
    Oh, no sorry.
    It was Quantum Leap I was thinking of
    flip
    Yes.
    Heisenberg is driving down the road and is pulled over by a cop.
    When the officer asks him if he knew how fast he was going, Heisenberg responed by saying, “No officer, but I know exactly where I am!”
    Oh boy!
    Markie
    Yes, carry on
    Oh, no sorry.
    shermer75
    Maybe this will explain:
    [video]http://m.youtube.com/#/watch?v=hc3kGyYyqgQ&desktop_uri=%2Fwatch%3Fv%3Dhc3kGyYyqgQ[/video]
    (The QL stood for Quantum Leap. Geek joke)
    molgrips
    What do you mean, how does it work? It’s complicated. The simple explanation is the one you just posted.
    A ‘normal’ computer, like the one you are typing on, the one in your washing machine, the one in your car, the one the Met Office use, has a CPU that has large number of bytes of memory. It starts at a specific point in memory then each byte is an instruction to do something like add or comapre numbers, or jump to a different part of memory. This is called Von Neumann architecture and has been around forever and a day. So you write programs to work stuff out, you break mathematical problems down into steps like you would do with say long division or something. So much so that people think breaking down tasks into simple steps is synonymous with all software. This isn’t true for the kind of software in which I specialise, which leads to endless frustration when people give you their requirements.
    But it’s not the only way to compute things. There used to be such things as analogue computers and all sorts of exotica. You could have a box of electronics where you put X volts into one terminal and the square root of X volts comes out of the other terminal. That’s a computer, cos it’s computing square roots, but it’s not going through a series of steps to calculate an answer like Windows Calculator does. It’s just set up so that an input is associated with an output in such a way that solves a given problem.
    Quantum mechanics then. One rule of this is that observing amy system must change it, because you are interacting with it. Following on from that, until you DO observe a system, it’s impossible to tell what state it’s in – furthermore, it doesn’t matter, and even furthermore still, it can be considered to be in all states at the same time. This is what Schroedinger was getting at with the cat.
    So a quantum computer contiains particles in a whole mess of states linked together in such a way that by interacting with its inputs its outputs can only exist in the state that represents the solution to the problem it’s been designed for. A bit like the analogue computer mentioned previously.
    Now I don’t really know anything about current QC research, but that’s how it works generally afaik. I could be wrong of course.
    CharlieMungus
    Really? It sounded more like an AI system to me
    Garry_Lager
    I’ve heard that company D-wave been dismissed as total charlatans by some quantum physicists, due to their reluctance to demonstrate calculations that would verify their quantum computer performance. I guess they must have been keeping their powder dry, seen as they’ve just trousered 15 mil from Nasa. It sounds like they are opening it up to scrutiny in that linked piece, which will be the proof of the pudding.
    mrblobby
    housed in a garden shed-sized box
    I’m surprised this hasn’t piqued the interest of the shed enthusiasts!
    CountZero
    That’s how it looks from the outside; inside, it’ll be vastly bigger…
    Quantum, innit. 😀
    darrell
    D-wave are charlatans. its not quantum computing just really really fast at calculating a particular type of algorithm
The topic ‘Quantum computers’ is closed to new replies.
