Speculatively… it sounds as if the noise is coming from your rebound damping chamber/ rebound damper. It could just be a normal noise associated with the damping oil swishing through the damper after a big hit? Then again… it could be (speculatively) air in the damper chamber that is making the noise, as it squelches / mixes with the oil. Air in the damper chamber would probably mean that you've not enough oil in there. Why would that be? I dunno.
This could all be irrelevant, as the sound could be perfectly normal – I know that if I move my Rebas up and down hard they sort of make a squelch too.
I know mine are due an oil change too, so I'm gonna be following this fantastic set of step-by-step photographic instructions for advice. Good luck!
