To answer your question:
QR15 feels a lot stiffer than QR – worth the upgrade if you like very direct tracking forks and pump your bike into corners. If you dont ride hard or pump into corners, you’re not going to get the same benefit.
QR15 feels very similar to 20mm, no discernable difference in stiffness – and I’m quite sensitive.
I’ve heard talk that QR15 is a PITA compare to QR at races, and I’d disagree – it takes the same amount of time to remove the axle as it does to loosen the QR.
I’ve had all three, and probably prefer 20mm – but the lack of wheel compatibility means that QR15 would be my choice of all new forks I buy.
Also…. Sektors are a great fork for the money, worth far more than they cost, Revs are superior and weigh less (like for like models), if you don’t care about weight (and TBH they’re not *that* heavy, then the Sektors would be a great buy.
