So does your inverter have more than one MPP tracker, Sharkbait?
My panels all face south but I have an odd number so they are all in series: in Summer I see over 700V!
1
Going to look into this more. I had over 800W at one point yesterday
Yesterday's peak was 1200W, the sun almost came out for a few minutes.
We're now inot the part of the year where consumption exceeeds production:
Production Consumption
Nov 163kWh 190kWh
Oct 301kWh 160kwh
Sept 353kWh 160kWh
Cooking the evening meal on the woodburner doesn't save as much as more lights and having to use the immersion heater to top up the solar-warmed water.
And mines going in today! Going to change the look of the house as we are completely flat roofed. One long line of shiny things.
So please explain this to me. As the peak electricity deamnd is during the evening, when it is dark, how will solar PV help?
My evening demand is low. I cook on the woodburner and turn on the immersion either when the panels are producing in the day or when I go to bed. I fil a flask with water heated on the wood burner so the kettle isn't on for very long in the morning.
It'll be easy to tell from the daily production graph. If it's the usual dome that resembles a normal distribution curve then the inverter is coping. More pointed and it's not. Frankly I don't see how it can work with an E/W installation without two trackers which is why I posted my original surprise that there is only one inverter.
I've had an email from the inverter importer saying that for our setup we would be better off with a twin MPPT inverter and though he has seen some single MPPT installations with the same E/W split as ours and they work well.
I don't want to be one of these people so I've fired an email to the suppliers/installers requesting a different inverter.
We'll have to wait for a nice sunny day before we can make anything of the data. At present all it tells us is that the weather isn't too good.
ohnohesback
We have daylight until nearly 10pm in the summer. But in hours of darkness you'd have to be importing electricity from the grid. The PV will contribute to the householders electricity demand in daylight hours. Any electricity not used when produced will be exported to the grid, and the system owner will be paid for this by the householders utility provider.
I thought the UK had a similar tarif system to France: you get paid more for you production than you pay for your consumption.
A solar hot water heater is your next purchase, Sharkbait. Your wife can run the washing machine when she wants then so long as it fills direct from the solar tank on the wash part of the cycle. It depends on the machine but 80% of the energy consumed is just to heat the water even on a 30°C wash. Madame has now learnt to change four valves and turn them back after 10 minutes. The financial payback is longer than PV though even if you DIY.
I would guess that with your system, you export all of it to the grid. There is then a calculation done of energy generated against energy consumed and the money relating to the balance is sorted out ie what you generated minus what you consumed. You don't consume your 'own' electricity.
Get everything on timers and run it during the day. They are doing this to modify your behaviour and get you consuming away from the 7am and 7pm peaks they want to flatten.
i have a couple of PV questions.. if the thing pays for itself in 20+ years, thats great news.. what other electrical products do you have that are 20 years old.. which of those is sited permanatly on your roof..
i can think of only 1 the tv aerial/ dish and i suspect few if any are 20 years old.. does anyone have a sky dish from circa 1991.. we did but it corroded to nowt at about 15 years..
Real life long term solar panel information:
http://info.cat.org.uk/questions/pv/life-expectancy-solar-PV-panels
They should last.
I still have my 91 sat dish installed and working, picking up French and German analogue signals; it'll go in March whe the Germans turn off the analogue signal. My Jan 92 Peugeot has been parked outside for very nearly 20 years and still fires first time every time (though the top layer of paint has peeled of due to the sun).
Solar World panels are guaranteed to lose only 0.7% of their initial production per year for 25 years.
You must log in to post.
