Viewing 40 posts - 1 through 40 (of 50 total)
  • Purgatory 2.3 – Rim Poll
  • iainc
    Curious after yesterdays thread.
    So I’ll start :
    mavic 719’s and tubes
    MartynS
    719 and tubeless.
    shredder
    B.O.R XMD 388
    Tubeless
    colournoise
    Flow and tubeless.
    alandavidpetrie79
    Flows & tubes.
    cnud
    Flow Ex Tubeless
    Nobeerinthefridge
    819 tubeless.
    steve_b77
    Crest & tubeless – big one though
    Simon
    DT ex500 tubeless.
    But also using an Eskar(which is bigger) tubeless on an XM719, no burps or noticeable tyre roll.
    iainc
    as an aside, in what dimension is an 819 bigger than a 719 ?
    Interesting replies so far, keep ’em coming !
    monkeyninja
    Wtb i23 tubeless
    akira
    Spank spike 35 and tubeless, come up huge.
    sv
    Flow & tubeless.
    richen987
    Easton EA70 XCT & Tubeless
    MarkLG
    Tubeless on Easton havoc UST (23mm).
    819 is the UST tubeless version of the 719 – it’s the same width.
    PJM1974
    719s tubeless here – on both my FS bikes.
    Bike one has Conti Rubber Queens. I’m Purgatory curious, so this thread is relevant to me.
    Bike two has Spesh Storm / Captain.
    Stevelol
    Is anyone running a butcher front, purgatory rear? Is this a good idea?
    jameso
    P35 tubeless. 29″ 2.2 and 2.3 Purgs (look about the same casing size to me).
    They’re not quite as big as some suggest, a step down from an Ardent 2.4 and a bit smaller than a 2.2 RQ, so about right for the listed size. Great wet-weather all rounders.
    wilko1999
    Yes, butcher front, purgatory rear on Arch Exs tubeless. Amazingly grippy and relatively fast-rolling set-up for most conditions. Although the butcher isn’t as bulbous as the purgatory if you like your front bigger than your rear 😀
    orangewinger
    Butcher front, Purg rear on Mavic Crossrides, ghetto tubeless using Gorilla tape.
    warns74
    wilko99 – Am considering the butcher/purg combo (both 2.3), but interested in your comment on sizing, are you saying the equivalent butcher comes up a little smaller than the purg, by how much would you say?
    thomthumb
    719. tubeless.
    Northwind
    Rear on Traversee EL and tubeless. (and a 2.35 Nevegal on the front).
    Personally I suspect that if people didn’t know they had narrow rims, most wouldn’t notice any tyre roll… Maybe we should blind test this and run around swapping wheels on people 😉
    sprocker
    Tubeless purg on rear and butcher on front. Cross trail wheels impressed so far maybe a bit of roll on purg but on rear and does not bother me. Butcher is v good IMHO and paid 52 quid for the pair not far off 1 maxxis
    philwarren11
    Butcher and purg with tubes on roval traverse on my 13 stumpy evo. Stock setup basically.
    wilko1999
    Hard to quantify without having the bike in front of me. Maybe a couple of mm across the widest part of the tread? Not sure on height. I’m going to have to check now, just out of sad curiosity 🙂
    chiefgrooveguru
    Butcher vs Purgatory:
    http://www.reifenbreiten-datenbank.de/reifen-Specialized-Butcher-26×2.30.html
    http://www.reifenbreiten-datenbank.de/reifen-Specialized-Purgatory-26×2.20.html
    (The Purgatory 2.3 is on the same size carcass as the old 2.2 version – marketing! 😉 )
    stcolin
    Superstar EVO’s, EN321’s, tubes, Minion/HR.
    godzilla
    Perg & flow ex with tubes, no probs.
    bigjim
    Arch, tubeless
    Yes. Yes.
    If this is in relation to tyres rolling on rims, my feeling is it is a side effect of tubeless – there is less there to be solid. Someone posted a video of their tyre rolling around on tubeless recently, mine aren’t that bad but it is noticeable, more so on low speed techy stuff where balance is more important. my Arch rims are relatively narrow though.
    acidchunks
    front, purg 2.2 on 721
    Rear, eskar2 2.3 on 721
    Both tubed, no issues.
    steve_b77
    And the award for not reading the op goes to…
    st colin – Member
    plyphon
    My 717’s are looking to be a bit thin 😆
    mboy
    Purgatory 2.3 on Pacenti TL28, currently tubed cos I’ve been too lazy to set it up tubeless!
    Nice profile to the tyre though, and grips very well!
    Gotama
    Tubeless on flow and P35. Might try stretching it across a dually at some point.
    MarkLG
    I got a pair of Purgs because the front Butchers weren’t available at the time. More than happy with them, but just ordered a Butcher to go on the front out of curiosity more than anything else.
    SOAP
    Mavic 317s tubeless with insulation tape and tubed valves.
    with Stan’s fluid.
    Flows tubeless with fluid.
    Both inflated with a joe blow first time.
    Bloody great tyres!
    bammy
    WTB Frequency I-25 Rim 29″ 2012 Purgatory F & R tubless
    olderigetfasteriwas
    Purgatory 2.3 front, Captain 2.2 rear, on crests.
    (No noticable difference in size between the two BTW.)
    Sorry, forgot: Tubeless.
    creedy
    ARCH EX tubeless.
    Purg 2.3 front(new) purg 2.2 back(old)
    The new 2.3 seems to come up massive compared to the rear. Great grip no roll or burps. run at 28psi +-
The topic ‘Purgatory 2.3 – Rim Poll’ is closed to new replies.
