Viewing 40 posts - 1 through 40 (of 69 total)
  • Purely hypothetically what's the lightest FS no carbon build?
  • 2unfit2ride
    Just for fun, build me a full suspension bike with no carbon fibre that’s usable as a do it all mountain bike.
    I’m guessing it will be short travel, but will it be sub 25lbs, sub 30lbs or greater?*
    * I was pondering this whilst trying to decide if spending nearly double the amount to save 100g’s on a pair of handlebars was worth it, & I still can’t decide 😉
    DiscJockey
    You need to be more specific about the type of bike you think is OK for ‘do it all’.
    If it’s the XC/Marathon category you’re asking about, then you can certainly buy something non-carbon for under 25lbs. Some people will happily ‘do it all’ on such a bike.
    Maybe you need to specify the suspension travel to give people an idea ?
    I suspect you’re interested in 140/150mm travel bikes ? Yes, you can achieve 25lbs with that much travel just with aluminium alloys….I can’t give an example, but you can….
    2unfit2ride
    Well to me do it all would be a lot less than 140/150mm, but then again how many people can actually ride a DH bike all day on the trail?
    Fresh Goods Friday 696: The Middling Edition
    Fresh Goods Friday 696: The Middlin...
    Latest Singletrack Videos
    njee20
    So what is it?
    I reckon you could do 20lbs if you were very careful, particularly if you went 26″ wheels.
    How strict are you being? Technically you can use XTR or XX1/X01 because it has a carbon cage on the mech and carbon shifter paddles? Are you avoiding it on structural parts only, or 100% metal?
    – would have to include ZTR Podium/Race wheelset
    – Extralite stem and post
    2unfit2ride
    Well the idea was no carbon, & there isn’t a lot of stuff available nowadays that doesn’t use it.
    njee20
    Right… No carbon at all.
    – Giant Anthem frame (no carbon linkages or anything AFAIK), 26″ wheels
    – SID RLT fork
    – Extralite hubs, Stan’s Podium rims, Revolution spokes (1100g or so, 1200g with Crests)
    – XTR M985 brakes
    – New Ultimate alu flat bar (only 600mm, gotta be a wider lightweight option)
    – foam grips
    – X1 shifter
    – XTR cranks
    – X1 rear mech
    – XX1 cassette
    – X11sl chain
    – Extralite stem
    – Extralite seatpost
    – Phenom saddle
    – Thunder Burt tyres
    – Egg Beater 11 pedals
    Reckon that would get you under 20lbs. Definitely the XC persuasion, but it’s a bit of a moveable feast otherwise.
    angeldust
    The stock Alu Anthems were well under 25lbs at one point iirc.
    njee20
    Seems likely, they clung onto aluminium for their high end builds longer than virtually any other manufacturer. Hence my suggestion 🙂
    Friends had some high end ones which weren’t light, forget how much they were though!
    chiefgrooveguru
    The Liteville 301 is incredibly light for a 160mm alloy full-sus – similar to the all carbon competition and a couple of lbs lighter than most comparable alloy frames. Obviously less ‘enduro’ bikes are available at even lower weight!
    The Giant Reign is bloody light too, though not quite as remarkable.
    jivehoneyjive
    This is probably close to as light as you can go on the All Mountain Alu front, though I’d be a bit nervous hitting a road gap on it:
    25lb Liteville 301
    richmtb
    Something like a Giant Anthem has a frame weight of 2.3kg for the Al version. Assuming 26″ 1*10 and no dropper
    1.6kg is reasonable for alloy wheels.
    900 grams for tyres
    700g for brakes
    250g for saddle
    200g for seat post
    150g for stem
    250g for bars
    100g for grips
    250g for cassette
    800g for crankset
    250g for rear much
    1.6kg for fork
    150g for shifter
    100g for headset.
    300g for chain
    300g for bits I’ve missed
    10.2 kg total not sure if I missed anything?
    Rorschach
    Crisps.
    munrobiker
    My Anthem was around 22-23lbs and had only a carbon bar. Can’t remember the exact weight as it was a couple of years ago.
    Spec was-
    SIDS
    Stans Olympic rims on Stans hubs
    Raceface Deus cranks, stem and seat post
    XTR 1×10 drive train with e13 zpxcx guide
    XTR brakes
    njee20
    Wasn’t the brief a ‘do it all’ ‘mountain bike’, rather than an ‘all mountain bike’?
    Not looked at your figures Rich but I can’t see how you’d get a 22lb bike with that sort of build – something must be missing!
    jivehoneyjive
    If there is a road gap, will a ‘do it all’ mountain bike be up to the job?
    Where is the divide between a ‘do it all’ and an ‘all mountain’ bike?
    Marketing men (and ladies) to the forum please!
    And what exact date did all mountain bikes become enduro bikes?
    Can you still enduro on an all mountain bike and vice versa?
    Will a ‘do it all mountain’ bike have correct gearing for an ascent of everest?
    How about K2?
    njee20
    How big is the hypothetical road gap to ride on the hypothetical bike?!
    mikewsmith
    Some of these builds look like they might snap if the hit a kerb a bit hard 😉
    Do it all really means do all that I do. For some people a cx bike would cover it others a 170mm beast.
    njee20
    With the exception of the stem And post (and tyres given conditions) I’d be happy my hypothetical build would be tough enough for anything I’d ride, and probably what most people do. Stem and post may be tough enough too, not used them, but something scares me slightly about a 70g alu stem and 98g seatpost.
    2unfit2ride
    My rigid Scandel 29er with carbon forks/bars/cranks weighs in at about 20bs, I just can’t grasp how a usable FS could get near that 😕
    deviant
    If you want to base the build on something more robust a 140mm Trance is also ridiculously light for an Alu built frame, don’t know how Giant do it, do they have a proprietary blend/brand of Aluminium?
    amedias
    Must surely be possible to do 120/140mm travel at that weight using just Alu and no silly light parts these days?
    My old 2004 Intense Tracer (100R/120F) was considered a trailbike then, and might still be to some people, that’s got mostly decade old stuff on it, and a few newer bits and still comes in just over 25lbs so using newer parts (especially wheels!) should be able to knock 4-5lbs off.
    But if we’re into ‘handle anything’ territory then it’s might need to be much burlier…
    Really does depend on the OP’s version of ‘do it all mountain bike’
    jonnyrockymountain
    My 650b anthem custom build with 120mm sids, XT brakes and 1×10 drivetrain, Thomson carbon bars, ec90 posted, American Classic wide lightening wheels and Nic an Ron tyres weighs 23.5lbs
    munrobiker
    2unfit- for a start mine had 9% less wheel than your Scandal. And it was build with a keen eye on weight.
    I used mine on all sorts- big days in the mountains (admittedly not very technical ones), XC races, mucking about in the woods. I may or may not have fired mine off some doubles as well.
    adsh
    What’s really scary is how quickly the compromises add up…… Take njee20s build and start to make it a little more comfortable/faster rolling 29er etc
    You’re adding a pound to the frame, half a pound to the forks, nearly a pound to the wheels (don’t think revs and crests works except for the lightest of riders) and tyres plus moving away from boutique hubs, stem and seatpost and pedals with more support and a more comfortable saddle (for me that is) nearly another pound. Whoops you’re atleast at 24lb.
    Would love to do a WW Nicolai TB build but will Liteville produce a ‘proper’ 29er soon?
    continuity
    Also you’re sacrificing a dropper, which for a day to day mountain bike is akin to dropping suspension.
    honourablegeorge
    adsh – Member
    Weight weenie Nicolai is pretty much an oxymoron
    whitestone
    A quick search on “World’s lightest road bike” brings up – http://www.bikeradar.com/road/gear/article/the-worlds-lightest-bike-36902/ but if we are looking at production bikes then http://www.trekbikes.com/uk/en/bikes/road/performance_race/emonda/ . I’ve seen the latter and it’s both mind bogglingly light and has a weight restriction on the rider! (that’s me out then) It also costs £11k 😯
    As others have said, lots of compromises or extra cost to get really light and as njee says a 98g seatpost is slightly scary. With my (lack of) skill level I’d prefer something that’s going to last. Still an interesting concept to mull over.
    njee20
    Melodramatic much?
    maxtorque
    Possible yes, sensible, no.
    Why would you build a decent long travel FS, and then fit tyres so lightweight (in order to get down to some nominal and completely arbitrary mass) that you’d never be able to ride it over anything it was capable of riding over?
    I’ve got 3 bikes:
    1) 100mm “race” hardtail, just 9.8kg. If you so much as look at a sharp flint both tyres burst!
    2) 140mm “trail” hardtail – 11.5kg with sensbible mid range weight tyres on. Fine in the UK mostly, but not burely enough for proper DH or the Alps without tyre issues
    3) 160mm “All Mountain” Full Bouncer – 12.8kg with chunky tyres, reasonably bullet proof for anything i’ve got the skills/bottle to ride
    Any of those bikes could be lighter, but that would always come with a penalty in terms of capability.
    deviant
    continuity – Member
    POSTED 1 HOUR AGO # REPORT-POST
    Lol, no dropper on my ‘day to day’ HT mountain bike, it is a luxury (a very good one) but a luxury nonetheless.
    I ride all over the place with it (Surrey hills, Bikepark Wales, Swinley, Cwmcarn etc) and I suppose I have the saddle an inch or so below optimum pedalling height for any unexpected technical stuff…on uplift days at BPW and Forest of Dean I just drop the saddle down and leave it there, if you can’t ride a MTB without a dropper you’re either very new to this or dangerously inept out on the trails…you should probably be wearing something hi-vis to warn others of your approach.
    adsh
    Yeah sad that. Was hoping they’d do a 29er version of the RC with slacker HA and long TT.
    whitestone
    A dropper post is in the “really nice to have” category, it adds about 600g over a normal post. I find the dropper is of most use on routes with lots of ups and technical downs, for long XC or bikepacking days then a normal post is fine. But if you are riding in a big group and waiting at the top and bottom of each section then you can just use the time to adjust a normal post accordingly.
    Tom_W1987
    I don’t even know why you’d want a dropper on a hardtail really, I am on the fence on the issue for my hardtail build. The simplicity of just running a front fork and 1×10 really appeals to me and lately I’ve been riding really well with the seat up.
    This, the people I ride with vary quite considerably in skill eg my brother is an ex DH racer so really really fast and we also give each other loads of space. Droppers are just a little easier to use, that’s about it at the expense of weight and reliability. I guess they are great if you don’t want to stop, but stops with chatting and arseing around is part of the way we ride.
    Rubber_Buccaneer
    What is too light or not may depend to some degree on your weight. Anyone nearer 95kg than 70kg is going to have a different requirement to me.
    whitestone
    I’ve a non-stealth dropper on my HT and swapping it for a standard post or vice-versa is simple. At the moment the standard post is in place.
    If I’m in a small group then often it’s a case of rolling “stops”, i.e. just go slowly let everyone catch up as the fastest get their breath back. A dropper is useful then. Still a bit of a luxury though.
    ahwiles
    Tom_W1987 – Member
    they’re even more awesome on a hardtail than on a FS.
    on a hardtail, everytime the rear wheel gets kicked up, the saddle gets kicked up. This isn’t awesome when your saddle is at pedaling height.
    on a FS, vertical rear wheel movement is obviously isolated (to some degree) from the saddle.
    if i could only have 1 dropper, it would be on my hardtail.
    Tom_W1987
    Good point, I haven’t ridden one in anger on really rocky stuff in about 10 years.
    Cheezpleez
    I ride a rigid bike with a dropper, which gives you an idea of my (weird?) priorities
    njee20
    I’ve never manually put my saddle down, let alone had a post that does it for me!
    mtbel
    that really is nothing to brag about
The topic ‘Purely hypothetically what's the lightest FS no carbon build?’ is closed to new replies.
Members Notice New deal added to Members Discounts
