A friend of mine runs them on his DH bike, seems happy. I’ve ordered 2 packs this morning (2 bikes worth) for the same price as 2 pairs of genuine shimano pads.
Been using them for a wee while now, seem fine. No better or worse that others, although I did read that the pad material is thinner than usual to make room for the metalwork – will need to check that out at some point
I took calipers to mine (say what you will, at least I know I’m sad) and found the pad material was actually just as thick. The backing plate is essentially halved in thickness so that there is the same thickness again for the fin plate to sit behind it.
Was going to go for the Superstar ones to replace the Uberbike ones I use, but SS don’t do replacement pads on their own or Hope M4 ones, and Uberbike do (means I don’t have to trim the Saint/Zee ones now).
The real test would be putting some on a dyno and measuring heat build up, then compare with some proper finned pads and a control.
Uberbike pads claim 55C, and are a similar construction to the superstar pads with a separate plate, but have fins which look a bit more like the shimano ones designed to work with airflow at different angles. Shimano claim 50C so it’s close. I can’t believe it’s better though, unless shimano are assuming an organic pad which would be insulating the heatsink from the rotor, and uberbike used a sintered pad? I can’t see the superstar ones being as good with those fins running straight, that’d put them almost vertical on the front brake.
Saw this too, I think the test protocol was to ramp up the power at 30min intervals. So ice tech works at 1050W, nothing else (OEM) does!
didn’t like the lever feel with the uberbike versions and they were a pain to set up compared to normal pads. got rid of them and went back to standard pads.
Cheers, Worth a punt for 4 sets for half the price of 1 set of genuine Zees. I can wear them out in Wales in winter and save the good ones for the Alps in summer 🙂
