” i25 are 25mm inner width. The Arch ex is 21mm inner “
True but not all rims are the same
Stans claim the lower (much more than most) sidewalls of the BST2 rims (FlowEX, ArchEX, Crest, etc) make them equivalently wider. They claim the 21mm ArchEX/Crest are equivalent to ‘normal’ 25mm rims
Comparing tyres mounted on my ArchEX’s to other rims (Mavic,DT,others) the same tyres do sit a lot rounder (rather than droplet shaped) and have much more volume because of the shape). They do so by grabbing the tyre lower down the sidewall, much closet to the bead hook rim of the tyre
Pacenti (TL28) are similarly low walled, haven’t really checked if they are quite as low walled
I don’t know what the rim/ty0re profile is of the WTBs
