8.17pm tonight the space station should be seen in the sky (if it's clear), we saw it last night at 7.52.
Face south then look up to the left, flashes past in about 20 seconds
Find out when and where to look here
EDIT: Space shuttle visible too!
Already spotted as it zoomed over head at 18:45, i will get another view at 20:20.It doesn't half shift!
meh, only visible for less than a minute tonight
would've been 3mins if i caught the 6.45 showing
can you see it with the naked eye?
Yes you can see with the naked eye (clouds permitting)
Yep. It's not the brightest tonight but you should be OK. Its just a dot but it does shift
Saw it a couple of days back, proper had a wriggle on and bright as you like (probably cos it had Discovery glued to it). Very visible with the naked eye, it's brighter and at least as fast as your average 737 (only bright white rather than flashy lights.
How high is it above the horizon? Low or straight up?
[edit] sorry, just read the link and noticed it gives angles!
Excellent, cheers lads, great information. I'll check it out tomorrow!
just rocked on passed glasgow. Easy to see if you're looking in the right direction!
was it multi coloured?
we live on the leeds bradford flight path so its hard to tell whats what!
Just spotted it again here
It was chasing a plane from where I was standing.
from where i am, it went right over the top of the glasgow flight path too.
no disco lights to report, I'm sure Mir would've put on a better show
piedi di formaggio - Member
Find out when and where to look hereEDIT: Space shuttle visible too!
Great find, looks like the shuttle is docked to it for the next few days, I guess that's why it's more visible to us.
We saw it last night, very exciting.
Heavens Above web site has details for all types of non-UFOs ISS and other satellites.
Give Iridium flares a try. Quite cool/nerdy
I use this site http://spaceweather.com/flybys/state.php?country=UK it gives the flyby times for your location.
caught it on the 1846 pass over central Scotland tonight. thought it was slightly earlier, so had a couple of minutes of thinking "is that it?", but very obviously something different when it came into view.
I saw the 7.13 passing in south Manchester tonight, it was very impressive, really quick and eerily strange.
i had a look, didn't see it down here in London. A few more days to try although it's getting closer to the horizon which will make it trickier
It was really bright here even though there was a bit of cloud. I thought I'd missed in and then it appeared and went right over my head for a good two minutes.
Looking again tomorrow.
Sorry I didn't revive the thread before we went out, but we've just had a good view of Discovery and the ISS whizzing by on tonight's transit. Last chance for the shuttle will be 6.36ish Wednesday for UK viewers with the ISS a few minutes later. Tonight they were about four degrees apart and a nice view together in the 10x50 binoculars. The leading one we assumed was the ISS as it seemed to have multiple light sources, but the timings for Weds suggest the ISS is trailing?
Anyway thanks to JohnClimber for the initial heads-up, my kids thought it was awesome, as did I. I'll try to remember to PSA on Weds.
saw them both at about 25 past seven tonight from Yorks dales, quite a bit apart, well smart!
