It looks very like the Fluxient which claims 3000 lumens from the same set up but tested at 1600 lumens in the MTBR test.
I saw that. Unlike the Lumicycle figures, the Fluxient numbers don’t add up on paper…
3 XML U2s running at 3A give 2,925 lumens according to the data sheet, so that’s almost 3,000. Forward voltage of 3.35 gives 30.15W. Assume the driver is 90% efficient so 33.5W. Battery is 8.8Ah @ 7.4V = 65.1Wh. Theoretical run time of 1.9 hours yet they claim 2.7h.
Compare with Lumicycle’s claim, assuming “high” mode is 1.5A, and you get 1,770 lumens and 2.48 hour runtime from the 2.6Ah (38.5Wh) battery (vs 1,700 lumens and 2.5h claimed), so Lumicycle’s claims are consistent with the datasheet.
There’s always going to be a difference between actual and datasheet, but I’d have rather more confidence in the Lumicycle getting close to its numbers.
