This looks identical to the Elite Novo Smart at Halfords, which you can get 10% cheaper with British Cycling. Does the Elite Intera come with a front wheel support? The Novo doesn’t though they are pretty cheap.
Worth noting while they are sold as Zwift compatible you have to use an Ant+ dongle, Zwift doesn’t control resistance over Bluetooth, it can only read the power this way. But yes set up right it will control resistance.
BTW as far as I can work out they are the Elite Qubo resistance unit in an Elite Rampa frame.
I tested it back to back with the Halfords Tacx Flow (again with an Ant+ dongle as Bluetooth dropped out a lot) and they are very similar but the main difference is the changes in resistance are more gradual on the Elite while on the Tacx it changed in steps, making the Elite feel a bit more natural. Also, while they are both spec’d to simulate 6% gradient, the Elite can absorb more power, and on a steeper climb it certainly feels harder if you want more of a work out.
Tacx positives it’s nicely designed, folds away better and includes a wheel support. They are both good budget options.
