Viewing 2 posts - 1 through 2 (of 2 total)
  • PSA: Bargain Claud Butler hardtail
  • grumm
    Saw this on bikeradar
    http://www.bikeoutlet.co.uk/products/Claud_Butler_Pinewood_2009-433-11.html
    Very good spec for £400 imo
    MODEL : Claud Butler Pinewood 2009
    FRAME : Claud Butler TC Hydro-Pro Frame. 6061 T4- T6 Aluminium Disc Specific Frame With Hydro Formed Top Tube, Compliance Snake Stays And Semi Integrated Head Tube. CNC Disc Drop Outs.
    FORK : Rock Shox Tora 302 U-turn With External Rebound And Turnkey Lockout, Adjustable Between 85mm To 130mm.
    GEARS : SRAM X-7 18 Speed X-7 Shifters And Avid Juicy 3 Brake Levers. CHAINSET Truvativ Blaze Chain Set With Truvativ Powerspline Bottom Bracket 36/24 Plus Bash Guard.
    STEERING : Semi Integrated “Aheadset” With Truvativ 31.8mm Alloy Ahead Stem And Truvativ 31.8mm Alloy 640mm Riser Bar With Locking Grips.
    BRAKES : Avid Juicy 3 Hydraulic Disc Brake System On Front 185+Rear-160mm Rotors.
    WHEELS : Ritchey Mountain Pro Disc OCR Eyeleted Anti Pinch Rims With Welded Seam Equipped With 32 Hole Alloy Quick Release Hubs With Sealed Bearings And Stainless Steel Spokes. 9 Speed Free Hub.
    TYRES : Maxxis Highroller 60tpi 26×2.35 – 60a Durometer.
    SEATING : Ritchey Marathon Comp Saddle Fitted To Laser Etched Claud Butler Alloy Micro Adjust Seat Post.
    SIZES : 18", 20"
    allyharp
    It is very good spec. Looks a bit rank though 😕
The topic ‘PSA: Bargain Claud Butler hardtail’ is closed to new replies.
