Viewing 40 posts - 1 through 40 (of 46 total)
  • PSA -29er pikes £365 140mm £439 130mm
  • Tracey
    Thanks, must stop looking at PSA, 140s and a xt front brake ordered, its not what you spend its what you save
    frogstomp
    Any ideas on the offset on these? Can’t find reference to the part number..
    NormalMan
    If only there had been a 120mm in there!
    Northwind
    Pretty sure you can drop 130 to 120 by cutting down the air shaft (you might need to recut the thread too).
    NormalMan
    That all sounds beyond me 😳
    Northwind
    Get drunk first!
    Alternatively, it’s just an air shaft swap. Not totally sure which one you need for a 120mm 29er Pike but they’re about £27 if you can find the right size. And it’s a really easy swap- barely any harder than a lowers service. (Which I know a lot of people are freaked out by but a lowers service is as hard as undoing 2 bolts, wiping your arse, putting toothpaste on a brush, and pouring a shot)
    stevemorg2
    Have emailed them re. The offset – could be just want I want on my fuel 29
    chakaping
    They will be sold out before you get a reply.
    Just assume 51mm, I reckon.
    You can replace air shaft and sell the one it comes with to adjust height.
    Not a very difficult job, but one bit can be quite tricky.
    zelak999
    Can you increase the travel to 150mm with a new air spring?
    chestrockwell
    Think so. My mate bought some 120’s and extended them to 140.
    frogstomp
    46mm apparently.
    chakaping
    Cool.
    I could have lived with 51mm but 46mm is preferable.
    frogstomp
    I’m the other way around.. have 46mm, new frame is 51mm! Probably debatable how much noticeable difference it’ll make, but would’ve been nice to swap at minimal cost.
    Tracey
    Looks like mine has been shipped. Think I read something a while ago where Mojo did a test on different offsets on a 29r and 650b Enduro
    stevemorg2
    Just been told by Canyon the 29ers are 51mm offset
    frogstomp
    Ha, I was told 46mm! Only one way to find out..
    Northwind
    frogstomp – Member
    True story… When I fitted my 34s in place of my Pikes, it felt exactly like how people describe the difference between offsets. I was just about getting convinced that this stuff matters, til I discovered that actually both forks had the same offset.
    I haven’t even bothered to find out what offset my 36s are, they feel normal so I’ll just presume they’re 51.
    frogstomp
    I think this is the article Tracey is referring to.
    Same offset but different A2C so different in other ways? But yeah, the differences are probably fairly negligible to the masses.
    Either way, nice new forks for the new frame won’t be bad, and gives me an excuse to use the old forks on a Shan GT!
    kimbers
    hmmmm some people I know could end up wasting some good whisky, have a minty fresh bum and a shitty smile
    Northwind
    frogstomp – Member
    The a2c was about the same with these 2 forks, less than 2mm different I think. Obviously the damping and way it used travel was different so things get lost in the mix
    Tracey
    Once mine arrive will post up the offset, would love to be able to do a lower service but think it may be beyond me.
    Thought the 28T SRAM chain ring was a good buy but apparently it may not come with the spider.
    peasant
    They have arrived and there 51mm offset (under crown) they have no service kit/pump but do come with bottomless tokens ,but unlike the advert there is no sag marker on the leg and black graphics 😐
    breadcrumb
    Looks like some how I’ve accidentally ordered two 140 Pikes. 😳
    Hopefully I can cancel one set, before they’re processed.
    Bit of a shock when I checked my balance!
    Vortexracing
    Mine arrived as well, not too fussed about the ‘OEM style’ sale.
    now I need a 130mm airshaft, anybody got one?? 😉
    Tracey
    Mine are at the Sheffield depot. Should have been ddelivered today. Will ring them tomorrow and rearange the delivery. Dont seem to be able to do it online. Hope mine have the black graphics and dont need another shock pump.
    mundiesmiester
    Any one know what steerer length?
    Vortexracing
    uncut
    frogstomp
    VR you have email..
    chakaping
    51mm and murdered out here.
    Packaging was like a lucky dip.
    stevemorg2
    My 130mm have just arrived – 51mm offset and 2x tokens – great for the money!
    Tracey
    Mine have arrived this morning, packaged well. Stealth graphics and 51 mm offset. A couple of chips, one on the crown and one on the front of the bridge. Can live with them as will probable get more on my next off. The front brake although shown as a right hand in the picture is a left hand so not much use apart from spares.
    breninbeener
    Ive had mine. Looks like a head race has been fitted but nothing else. Great PSA, thanks OP!
    breadcrumb
    Mine are on the way.
    Just need to either source a 120 air shaft or cut down the one that comes with it.
    frogstomp
    Breadcrumb – you have mail!
    breadcrumb
    Thanks frogstomp 8)
    breadcrumb
    Just back on from my first ride with these, wow, pretty impressed and they still need a bit of fine tuning.
    fd3chris
    Just received mine, 140mm version and they look lovely. Come with tokens and totally blacked out stanchions.
    blastit
    Mine are fitted and fantastic,
    thanks Peasant
    fd3chris
    Yep thanks. Best PSA for me ever on here.
The topic ‘PSA -29er pikes £365 140mm £439 130mm’ is closed to new replies.
