ok i found this
“If you are having an issue after the update where the TV icons are not appearing, there are a number of things to try.
Signing in and out of HOME can prompt the icons to appear (this is also the case with other software this can be tried with: Vidzone, PlayStation Store, MUBI, Lovefilm).
Deactivate and Reactivate your account on the console.
Refresh your internet connection settings to the PS3, (or you could also Sign in and out of your account to test if this has any affect).
If the Icons still do not appear:
Restore default settings on the console by going to Settings>System Settings>Restore Default Settings.
You can also try Safe Mode Option 3 (if this does not work attempt option 4). For more information on Safe mode before carrying out this process:
Using the Safe Mode function on your PlayStation 3
The icons should appear after a period of time (however some of theses steps can prompt the icon to appear sooner) .
Any issues, let me know
Rabid”
here is where it is from
