How long a cable is “longer”?
About 12″ longer than the stock one. Not much. I could move the PS3 but then it wouldn’t be in the middle of the bench it’s on, and the optical cable woudn’t reach the AV amp for movie purposes.
Why not just use your AV amp?
Because the hifi amp is quite nice, and connected to relatively decent speakers. The AV amp otoh is nowhere near as nice quality and connected to some budget tannoy AV speakers. Music through the AV setup sounds awful by comparison – it has been tried. The AV amp only has one set of speaker outputs so I can’t wire that to the same speakers as the nice hifi. It does have pre-amp outputs though so I could wire those directly to the hifi with a long enough cable but that would have to be quite long. Not sure if it would sound better or worse than using the DAC in the PS3 but it’s worth a try. But that means three remotes, although they aren’t used a lot when playing random background music during the day.
Although.. an obvious idea would be to switch the AV amp to the cabinet in the other side of the bench… that would solve the length issues!
Already have the PS3 remote btw but even better is a PS3 slim that can be controlled via HDMI through the telly. Works most of the time, until some app requires you to push triangle or L1 or something.
