How we finish how Bespoke wooden surfaces is using 50% White spirit
and 50 % Danish oil.
Oil this combo for 7 days, and also sand with a fine grit paper
before you put on the next coat.
Using white spirit at first raises the grain of the timber and allows the Danish oil to penetrate into the timber easier.
Then use 100 % Danish oil each day until the surface cannot hold
any more, also sanding with a fine grit paper as above.
DO NOT pure the oil directly onto the wooden surface And DO NOT pure
on neat.
Make sure you coat the under side too, and you can use neat oil here.
Doing the above intructions will give you a finish as though it was
sprayed Lacqured
