DIY/building/electrical content below…
As part of my ongoing renovation project I want to put up a new false wall in front of an existing one. Our place is in a block of flats and some of the services (mains gas supply and mains electricity – the three-phase 400V cables) pass up from one floor to the next through the hall of each flat. They’re not chased into the wall or otherwise protected, though the cables are chunky, presumably armoured to some degree.
Originally there were ugly built-in blockwork cupboards around them, with the meters at the bottom and the pipe and cables running up the back, fully exposed – clipped to the wall in the case of the cables while the gas pipe just runs vertically an inch or two from the wall in the corner. With the useless upper parts of the cupboard removed I want to box the back wall in entirely to conceal the cables and the rough blockwork of the original.
Unfortunately while I would know not to drill or nail there, the cables would run right up the middle of a tempting area of flat new wall, just right for a future resident to want to hang a nice picture of some kittens and try to whack a screw or nail right through it. The electricity meter and newly replaced (professionally!) RCD unit for this flat are just below, in the cut-down remains of the cupboards, and the cables that supply the flats upstairs visibly run directly up from there, but I’m not sure I can certain I can’t rely on people to check before hammering away.
What’s the best thing/statutory requirement to do to avoid crispy-fried future owner? Some kind of protective plate? Making the false wall deeper so that drills/nails can’t possibly reach?
