Viewing 21 posts - 1 through 21 (of 21 total)
  • Prophet Pivot bearings – what size are they
  • racing_ralph
    Anyone know so i don’t need to take my bike apart!! cheers
    racing_ralph
    bump
    racing_ralph
    and again
    dale
    swing arm bearings 6902
    racing_ralph
    ta – 2rs i presume? Getting a new swing arm – will it come with bearings fitted?
    saladdodger
    Ask your lbs
    racing_ralph
    is it open – is i ****!
    dale
    rs is right good luck with swing arm fitting it yourself?
    racing_ralph
    aye – easy enough
    saladdodger
    pppppp
    racing_ralph – Member
    proper proir planning prevents p155 poor performance
    you did start this post 2 days ago
    racing_ralph
    the swing arm arrives in 3 weeks! POYPT
    DustyLilac
    15 x 28 x 7’s
    Try EBR Bearing Supplies on fleabay
    racing_ralph
    thanks dusty
    DustyLilac
    They’re the ones. I use a big bolt, some washers and a big socket to fit them. So, big socket on outside of swingarm (bit of tape on there to protect), big washer to stop bolt pulling into socket, press bearing in by hand as square as possible as far as you can, then washer just smaller than bearing o/d – about 26mm – then the nut and carefully tighten. Did that make sense?
    A big G-clamp may do it too with care.
    racing_ralph
    i have a metal work vice and a bearing ress so should be ok 🙂 cheers matey
    DustyLilac
    Very semi-pro 😉
    racing_ralph
    are SKF bearings worth £7 each more?
    DustyLilac
    SKF are standard C/dale fitment, strange that the PDF manual for the Gemini lists the size and manufacturer, but there’s no reference to the bearings in the Prophet one other than the C/dale part no.
    SKF are premium quality bearings I believe.
    racing_ralph
    SKF it is then 🙂
    DustyLilac
    Because you’re worth it…
The topic ‘Prophet Pivot bearings – what size are they’ is closed to new replies.
