So your going for an early model “new” mini then ?
Which model ?
Few things to bear in mind (speaking from painful experience)
1) The gearbox on the One + Cooper (but not the ‘S’) are prone to failure around the 70k mark. Around £300 for a recon unit + fitting; replace the clutch whilst you are in there.
2) Engines are generally strong; but can be prone to going bang if it’s been allowed to run low on oil (e.g. you get a leak and the first thing you know about it is when it starts making all the wrong noises on the motorway)
3) The PAS pump can be prone to overheating; I believe there’s an updated alternative that’s better.
4) If it’s still on run flats and you like to .. ahem.. enjoy spirited driving it’ll go through tyres at a surprising rate of knots. Best change I ever made was to regular tyres + a can of gunk.
5) Water pump housing is prone to cracking / failure
6) They are great fun to drive 🙂
