Viewing 3 posts - 1 through 3 (of 3 total)
  • problem with a Maxxis High Roller
  • Pook
    anyone had any issues with high rollers? I can’t get this new one to seat on the rim at all. No matter what i do, on one side there seems to be a flat spot on one side where the bead doesn’t ping in. As a result, when rolling the wheel looks like it has a kink to one side, and when you roll over that point on the flat, it’s a flat spot.
    I’ve just been wrestling with it to try to get it to click in but it won’t play at all.
    Any ideas?
    TrevorB
    Have you used soap to lube the tyre? I use cheap neat washing up liquid.
    Pook
    yep – no go!
The topic ‘problem with a Maxxis High Roller’ is closed to new replies.
