A few DB Prince Albert owners here, I'm led to believe.
Need to fit some 426 Air U-Turn Revs (with all the adjuster gubbins on top) to a 15.5" PA frame, and it seems that fork adjuster/downtube clearance may be a little tight.
Anyone have any suggestions for/experience of headsets that'll allow adequate clearance between fork and frame?
Current fave (Cane Creek S8) with 12.3mm lower stack height looks tight, if my cunning bog-roll mock-up is to be believed. Hope HS looks more promising with 14.1mm. Any good?
Merci bucket, gentlemen...
