I have a Schraeder drilled rim (Halo Freedom) that is quite a loose fit with the tyre (ADvantage). I keep tearing a small hole round the bottom of the presta valve. The rim didn't come with a presta insert. For consistency with my other bikes I'd like to keep using presta and have used presta on other Schraeder drilled rims without problems. But I reckon this rim/tyre combo is too loose and moving about too much putting strain on the valve.
I've had a quick look on CRC and can't find any inserts for using presta tubes. Anyone know where I can buy them? The Halo Freedom is quite a deep rim – does that mean I need a deeper insert?
I like the rim and I like the tyre so I'd liek to keep both if poss. I'm planning to bung another layer of rim tape in there, quite a wide one so it gets right up under the bead. Any other ideas for making sure the tyre does not slide around too much.
I will not be going tubeless (but don't let that stop you suggesting it ;~) ). Apart from anything else I very much doubt this tyre would ever seat/seal on this rim either 'ghetto' or with a conversion kit.
