My heating was patchy even after balancing, 17 rads on two zones and water heating.
Fitted one of these after draining the system,
http://www.screwfix.com/p/sentinel-eliminator-system-filter/77150
and filled back up with two tubs of this:-
http://www.screwfix.com/p/sentinel-x800-heavy-duty-sludge-remover-1ltr/84921
Now after a few weeks the sludge/metal fragments have stopped coming out of the filter when I drain it and the boiler has been turned down to just above half way on the stat.
The hot water has also been turned down on the tank, as it was getting too hot.
All the rads can be on at once and are all properly hot together.
Found tapping the rads with a rubber hammer helped dislodge the sludge, with the pump on top speed and the valves fully open.
£130 in total and will drain it next month and re-fill with inhibitor.
