HI
I know a lot of people on here are good with networking and IT so thought someone would be able to advise.
I have 2 old 7dayshop powerline adaptors which help the computer furthest away from the router connect to the internet. Despite my best attempts the receiving unit seems to be broken (reset / moved to room where sender unit is / used as sender instead of receiver – nothing seems to get the Ethernet light on!)
So it seems I need to buy some more – I have BT broadband with around 17 meg speed in the house wirelessly
My question is can you mix an match powerlines – they don’t stock the ones I have and the are an old model and also in terms of speed, most now seem to be 300 / 500 or 1000mbps – mine are 200 – would mixing them mean that the whole system was limited to 200 by the old unit or would the others work on their max and just the 200 unit set as a receiver limit that outlet’s speed.
Thanks in advance for any help!
Al.
